Questions about wagons with notches
okcderek@yahoo.com's avatar
okcderek's avatar
okcderek
I just got bags put on my wagon, which happens to be first bagged vehicle and just so you know...IT RULES!!!!! My question is for those who have wagons or have had wagons...how did you notch the rear frame? And do you have any pics? Want to notch mine but was told would have to raise floor and driveshaft tunnel even for 2.5 or 3" c-notch. If that is the case then I should just step-notch it and raise the floor. I was trying to not have to do all that so any input on what my fellow wagon owners did would be a great help. So I can the family TRUCKSTER
baggedwagon69's avatar
baggedwagon69
frist thang frist do a custom 4 link bro trust me on that you do need to raise the floor a bit and the driveshaft tunnel but also if you do with the stock 4 link u need to extende the upper and bottum links so the wheels are not pulled forward to much when air out
okcderek's avatar
okcderek
Thanks for the info. Anyone else amd anyone have pics of rear suspension of their wagons.
okcderek's avatar
okcderek
BUMP
GarrickArends's avatar
GarrickArends
If you plan on body dropping it at any point then you might as well do with what Brent said and save your self some time.
fyi... wagons can be a bitch, but the end result is worth the work!
shagwagnva
pictures of wagons with bags need cup size goin to custom build air bag cups
baggedwagon69
on my wagon the bottum cup is only an inch tall and i do not have a cup on the top mount the bag to a custom made bridge on top
