Chevy/GMC Trucks \  Decisions..Need your help
views 256
replies 10
following 8
Criscone   +1y
Ok well i am new to the mini-truck scene. I was into the whole 'car scene' which after 4yrs of that, it got amazingly old. Anyhow i picked up a 98' S10, short box/red cab/5 speed/2.2 etc. I am debating weather or not to bag it or just slam it on 18s and buy a bike in spring. As for if i go "bags" heres my setup id run.
12 Gal Tank
Blitzluft 1/2" Valves (
2600 Bags in rear
2500 Bags up front
Switch box (looking for just a 4 switch)
DOT 1/2" Airline & DOT 1/4" Airline
Airlift Single Need Gauge
SMC 1/2" Water Trap
SDD 1/2" Check Valve
Belltech 2" Drop Spindles
S10 bolt on Bag Brackets
SD Bridge Kit
FBI 4 Link Kit
Tranny Crossmember
Besides fittings am i missing anything at all? Relays? Any misc items? Any more gauges?
As for compressors, i am un-sure on what to run. Ive been told (2) 450's will do the job nicely yet my friends say convert my AC Compressor to fill my tank. So i need some advice in that department as well.
Or just go with a 5/6 drop on 18s and pick up the 03' R6 off my cousin...(has UNDER 300 miles on it)..
bendapirate   +1y
BAG IT!!! Everything sounds pretty good. I'd go with a Suicide Doors 4 link though.
Criscone   +1y
yah i figured i might as well just bag it. But my MAIN concern is compressor. Can i truly run my AC comp as my airtank comp? I have lots of friends telling me different things. So lost at the moment.
turbofrontier   +1y
I agree bag it I have a 98 s10 and im selling it to finish my frontier that im bagin its just not the same with out bags i say bag it and drag it
olskoolpup   +1y
i dont think the factory ac pump will pump air very well. the ones ppl are using are yorks and sandens. both require custom mounts, water/oil separators, and fittings. the york will require less maintenece since it has an oil resevoir that stays filled. just check the oil every once in a while. the sandens require an oiler or daily oiling. both will pump 200 psi no problem. good lucka nd welcome to the scene.
Criscone   +1y
Thanks guys.
oh about drop spindles..what brand should i go with? Ive heard go with beltech, than a friend told me "aim??" has them for udner 100 but there not beltech. Im ordering all the stuff for the front right now, than moving onto the rear.
L T   +1y
Drag it!
YUPPIE   +1y
CALL JEFF @ HARDLUCK CUSTOMZ!!!!! HE WILL HOOK YOU UP
overkillfabshop   +1y
like someone else said above... everything looks good except the 4 link, i would use fbi's 4 link on a gocart, unless theyve totally revised it, but i dont think they have, just my opinion id use a 4link from kp or jason at suicidedoors.com
Criscone   +1y
Dizzug...you do know that the titanic sunk right? So how proffessional is that? haha
Ok cool, well im getting ready to order some stuff soon. valves/tank/gauge/lines/switch box etc etc
