question about datsun compatability
F
GonnaDragAn87
i've got the oppertunity to pick up a running 70's modle datsun pickup and one norunning both with the l20 in them. I currently have a 67datsun pickup and i want the front disk breaks off the 70's extended cab. will they work on my 67? and will the l20 fit right in where my stock 1.3liter is? The 70's are autos and the 67 is a 4spd.
drgnbdy's avatar
drgnbdy
hardbody dropped spindles will bolt up and you can use a toyota hub on that to get the 5 lug if you have the spindle machined just a hair to allow the bearing to seat on the race correcttly.
dragmatic's avatar
dragmatic
Man..all you lucky people finding bulletsides. I need a set of those hubcaps and wheels for my 720.
boooghar's avatar
boooghar
fas ....... i was using a 620 hubcap for a frisbee in a junkyard a couple weeks ago, but being in arizona, you see that stuff all the time
GonnaDragAn87
will the l20 bolt up to the 4spd tranny of the a13 or whatever it is
toffeechips's avatar
toffeechips
toffeechips
oh he said 70's not 70 oopsie
1SICKCANYON's avatar
1SICKCANYON
Some one buy my 71 datsun project!!!! $500 bucks
balcar's avatar
balcar
I'm not sure, but nissans are pretty good about keeping things compatable like that most of the time. Just look where things bolt up to the frame.
TwistedPhil's avatar
TwistedPhil
Your 67 uses a kingpin front suspension, so the disc brakes and control arms from a newer model won't just bolt up- you'll have to cut the whole suspension off the donor truck to swap it.
As for the motor/ tranny swap, all of the mounts are different from the pushrod 1300 to the L series motor. You can cut the mounts off the donor truck and weld them to yours, or you can just swap your 67 body over to the newer frame and save all that trouble! Some of the body mounts will be different, but widths are mostly the same, so this may be the easier way to go... good luck!
-Phil at FBI
