layin out a 89
N
layin out a 89
draginzuzu
Can I lay out an 89 on frame without spindles?
DawgsledMazda's avatar
DawgsledMazda
depends on wheel size, but if you plan on running an 18 or larger, you will need drop spindles or drop arms.
HotRodDime's avatar
HotRodDime
are you talking about a Toyota? if so it can be done without spindles for sure hit up sadisticiron (that's his screen name on here) he layed out his yota on 20's with stock spindles and he still gets tons of lift!!!
draginzuzu
No its an Isuzu pickup, I just got it for a work truck and I have all the stuff from my rodeo here so Im gonna bag it, I layed my rodeo with stock spindles but it was way more work than what Im gonna do with this one,.
dragn168's avatar
dragn168
its possible just notch where the lca hits the frame and your good or for $150 you could get lowers from byc
SN
SHORT n SWEET
Spindles suck on PUP's, it increases the track too much... so i would make it lay out without them for sure...
TRUCKIE
then u will fuck ur ball joints....
u could also 'z' the front, thats wot we did to mine...
and it fully lays- layed
CompleX
yea i gotta figure out a way to lay!!!
F
FrameLayN88
The notching of the frame on the 89 will not cut it. your ball joint will only flex so far & notching the frame will not help. My ball joints stop it before my LCA even touched my frame. Depending on what size wheels & Tires you will be running you might need drop spendles.
FrameLayN88
Isuzu
Related Discussions in Isuzu
