blowing efi fuse
blowing efi fuse
red94toyota
ok heres the deal i cut out the front fender wells on my pickup and had to relocate everything battery, power steering....and now when i turn the key to start i blow the efi fuse i dont know what i did can anybody help me???
cookiemonster13's avatar
cookiemonster13
YOU NEED TO CHECK SOME GROUNDS. I WOULD SAY YOU MOVED ONE AND DIDNT GROUND IT OR YOU MOVED ONE AND DIDNT GROUND IT GOOD ENOUGH.
red94toyota
ok thanks ill try moving some grounds around
jackson-vc's avatar
jackson-vc
ive seen the same thing happen when a battery was hooked up backwards on a toyota. check and make sure no grounds were accidently connected to a hot wire.
hope this helps
time1's avatar
time1
its a ground...its happened to me before. i relocated my battery to my bed and the ground to the frame wasnt a good one.
red94toyota
is there any way the short could be in my mass air flow sensor because i unpluged it and the fuse doesnt blow now
xmdragonass's avatar
xmdragonass
thats not possible your truck wont idel without your mass air flow sensor... i once was blwing my efi fuse, it turned out to be that my wiring harness was getting rubbed through from my steering shaft, everytime id turn it would rub the wire and blow it..... check all your wiring, thats gotta be it.....
