1st gen s-10 motor swap
sjudd86
I have a couple questions about the v-8 swap in an s-10. Im body dropping my truck to the rockers and for one need a definate answer on whether the v8 will fit with a 2 1/4 cowl hood, second. what motor mounts have you guys used. Stealth conversion kit has the brackets but didnt know if they were to thick and would cause hood clearance problems. i need help with this, any help would be appreciated.
SteveForePlay
cruisinlowS10
my truck isnt body dropped but i am quite pleased with my JTR motor mounts.
sjudd86
bump
low_blazer's avatar
low_blazer
I'm running JTR/Stealth conversion mounts with my bd'd blazer. It would work out with a cowl hood no problem. Also, if you're looking for headers that clear, the advance adapters slick fits clear the steering column with no modifications..
cdndragrr
i used to have an s-10 that i was gonna drop a small block in i have some motor mounts for that just kickin around in my garage
SoLow03
I've got the Advance Adapter motor mounts and have no problem fitting the motor under a 2 1/4" cowl hood. The trick is finding an air cleaner that will allow you to do so....which in my case will be the Holley one like Lackey's got on his Blazer.
Chris
sjudd86
guys i appreciate the info,cant wait to start doing the swap and the body drop, thanks again.
