Ford Trucks \  ranger fuel cells
ranger fuel cells
Ford Trucks Make Specific
views 611
replies 15
following 12
slammed2000ranger   +1y
i was wanting to know where i can find a fuel cell and what kind of fuel pump to use and where to find that? please help
bodydropped85   +1y
hmm ur name says 2000 ranger so its a return less system. as far as fuel cells, summit racing for the cell and pump.
my buddie is running this pump on his truck
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D2225&N=115&autoview=sku
with this fuel cell.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=RCI%2D2151AS&N=115+4294839036+400379&autoview=sku
thanks . do you know how hard to put in or is it pretty easy with insructions??
bodydropped85   +1y
umm there not gona come w/ instuctions, ur gona have to figure a way to make ur fuel system non returnless....
ontheground   +1y
i ran a 15 gallon cell in mine with paxton fuel pump, as for return line. i ran a new line from motor to the top of the cell. just put a balk head in it and conect the lines. also make a breather set up on top of the cell
tuckin eh   +1y
his truck is a 2000 therefore hae has no return line comming from the motor. easiest way to do it is to use your stock pump/sending unit. get an aluminum cell and drill holes in the flange around the stock unit and bolt it down using a gasket sealer. it may require using a spacer depending on what pump you have. some motors and gas tanks' units are different in length. oh get a cell that's 10" deep. it should be close to the right depth.
rangerrudy   +1y
My gas tank is in the factory spot but it is raised up! It's a whole lot easier than buying all that stuff and finding the correct fuel pressure for the truck! Believe me, I've been down that road before!!
oneandthenanother   +1y
performance products knoxville tn talk to karl where i bought two from
tuckin eh   +1y
good luck raising one on an extended cab
lobitoranger   +1y
try to find a smaller, flatter stock tank to run with stock fuel pump
