i want to do a u-turn
onetimesoldier@yahoo.com's avatar
1time's avatar
1time
hey fellas
I have searched the archives and found no help. I have a 89-95 toyota truck with rs62 slams up front which are installed traditional-style. The brake-line bracket inhibits the steering from going through its full range of motion. If it was not stopped by the threaded steering stops it would hit the bag. does anyone have a toyota with this problem, or does anyone have a remedy for this?
thanks
Low_SST's avatar
Low_SST
relocate it and extend your lines if necessary.
DawgsledMazda's avatar
DawgsledMazda
best way is to get tube arms with a drop built in and run drop spindles. then you can move the bag way down under the frame, closer in to the pivot point, get more lift, a tighter turning radius as well as eliminate your strut rods, get bag mounts, correct balljoint angles and have clean ass looking parts. solves several problems at once.
