Mazda Trucks \  redrillin hubs
redrillin hubs
Mazda Trucks Make Specific
views 608
replies 12
following 11
roknmotor   +1y
since i cant find out if the aerostar conversion really works or not, i am going to just redrill my mazda.. my question is what is the best way to do it.. i am going 5x4.5 the local machine shop will not do it unless the center bore on the wheel fits perfectly on the hub, if that was the case i would just mark and drill myself.. so i am going to have to remove the old studs and grind those tabs off the hub and mark my holes some how... is there a trick to make sure you drill in the right spot and make the wheels centered on the hub???
Low_SST   +1y
you would have to cnc machine them but there is some shop that sells the hubs already redrilled and set up for a bunch of different bolt patterns. Do a search for the same topic and you should find it.
WickedKustoms   +1y
i can get the front redrilled and ready to go for u just hit me up.
JOsh
sandog   +1y
Trikblue86 He will do it.
TOYBOY89   +1y
I sell a custom machined chromoly hub for Mazdas 86-93, see my website http://www.nolimitscustoms.com, but pay no attention to the pricing I have dropped the pricing, call me for prices 604-454-8919
They are all drilled to 5x4.5" and 5x4.75" bolt on, no messing around, if you can do a front brake job you can install these hubs no problem.
Deuce   +1y
i'm buiding and selling billet aluminium 5 bolt hubs, if your interested you can reach me on my email and i will give you prices and pics. my email is phattys_fabs@hotmail.com
lukeinva   +1y
Anyone know if a hub from a 626 or other mazda with 5 lugs will fit on the B2000?
Deuce   +1y
the answer is no they won't, but mine billet hubs use stock mazda rotors, pads, bearings and bolt directly on to your stock spindle and even drop spindles.
kustomfab   +1y
Laynrockers will redrill them for you.
slamdamazda   +1y
Listen to Justin(thefabshop)send them to laynrockers or Josh long.
