Right side is higher up then left side on air
Euromaxima avatar
Euromaxima
For some odd reason it looks like my right side has more air in it then the left. what could cause this? if you look at the bags the right looks more inflated? how can i fix this. thanks
Low_SST avatar
Low_SST
its the chevy gangsta lean.
lo75lux avatar
lo75lux
must be the gangsta lean, my brother 93 F/S does it too
lownoma99 avatar
lownoma99
GMs are known for that. gas tank, driver all play a part in it
GarrickArends avatar
GarrickArends
like he said... more weight to that side. My wagon does it a tad bit too.
Piecessan dragger avatar
Piecessan dragger
might want to consider running 4 valves up front if your not already. that way when you get it up you can let a little more pressure build up in your tank and pump a little more in the side thats draggin. if your only runnin 4 valves total your just gonna have to get used to it doin that a little.
