Gumby's celica (HELP!)
sk8bha@aol.com's avatar
dragndime's avatar
dragndime
im buying Gumby's old lime green celica, and i want to put juice back on it. does anyone have any idea how it was done before? or the best way to do it?
i heard they had some problems with the way it used to be, but i dont know exactly. can anyone help me out? thanks
9
97project
i already answered this question.... :sawzall:
I
IGotIssues
hit him up He will def help you out
Pp_Laynbody
http://www.streetsourcemag.com/IM/viewusercontent.aspx?IMStyle=2&ID=gumby That is his profile, IM him and i'm sure he will give ya all the help you need...
dragndime's avatar
dragndime
i im'd him trey. thanks.
just looking for anyones opinions on the best way to set it back up.
shavedmax
i think he originally was running 1 pump with a manifold, but i could be wrong. i've done that and it's a PITA. buy a 2 pump kit and start from scratch. i dunno how stuff mounts up on a celica, but you can ususally use the front struts to make housings for the cyliners, or run reverse flows, but theyre smaller. either way you're going to need a welder
MS
Mr Scrape
you could bring it to me & I can do it since josh hates juice so bad. Im glad to see that there is someone down there that josh hasnt had the chance to brainwash about juice yet. JUICE IS AWESOME
O yeah this is Robbie. forgot I was in scrapes name
dragndime's avatar
dragndime
thanks robbie. got an email addy?
AON-4PumpedCL's avatar
AON-4PumpedCL
He did ProHopper Mid 6's up front. Regular flow, just mounted upside down. I think he did 8's in the back...not positive on that though...may be 6's back there too. I would do a 2 pump, 4 dump. Should be quite reliable if it's installed well.
-Aaron
dragndime's avatar
dragndime
thanks for the help man. i just want to get this all done right. i plan on driving this car a good bit, so it needs to be reliable, but i still want it to sit as low as it did when he had it.
s10
last post by baha +1y
