82s10&93F/S
chris07tx@yahoo.com's avatar
82s10&93F/S
lo75lux's avatar
lo75lux
ok...i have a 82 s10 siglecab and my bro has a 93 F/S, his is bagged on 22's but not layin frame,and i want to put 22's on my s10 and lay frame, how hard will it be?
cruisinlowS10
lets see...I forsee firewall tubbing, smaller brake booster, modified heat box or no heat box all together, no inner fenders, tubular control arms are going to be your friends, notch in the frame for tie rods, its going to be a challenge to keep the 22's under the hood and under the bed rails...theres more i suggest you read read read. s10forum.com baggin it section is a good place to start.
sjudd86
you wont have to worry about hood or bed rail clearance if you are just going to lay frame, but you will need everything else he said to lay out.
AbsolutMinis
search for some of the s10s in the owner profiles. 4uh8rs
has some good build pics of his blazer on 22. just to give you some reference as far as front clearances.
