how to tell the difference?
deflaytedwayz2
Edited: 12/2/2005 9:58:25 AM by deflaytedwayz2
how do i tell if i have a small hub or large hub rotors? im thinking on buying rims and they say they fit all small hub s10's i have a 96 hombre but same difference when it comes to suspension. also if i find out i have larg hubs can i just buy the small hub rotors? and bolt them on or will i have to change calipers also? thanks for any info in advance. oh one more will 20's with a 35mm offset tuck on an s10?
travis98s10's avatar
travis98s10
35mm offset is too high. you only need a +14 unless if you want to run spacers which is stupid.
bdroppeddak's avatar
bdroppeddak
you could run a 35mm offset, but if its smaller than like 8.5" wide you'll probably rub the frame.
deflaytedwayz2
okay, so maybe the small hug thing and the 35mm fits all 4wd s10's? that would sound more reasonable. so +14 is what im looking for? what that in inches in backspacing? im planning on going 20x8.5 in front and 22x8.5 is i can find any or 22x9.5 cause that seems more comon what back spacing do i need for 22's?
