AirRide and Alarms
AirRide and Alarms
kevin@aac
Who has made there vehicles "dump" when armed? I have a compustar alarm, and I need to know what I have to do.
time1's avatar
time1
Edited: 12/3/2005 10:23:28 AM by TiMe_1
i can dump my truck with one of the AUX switches on my alarm remote
my switchbox has a spot to hook up an AUX from my alarm. thats how i can do it. Its an AVS switchbox.
themightypace
you could... the alarm arm is a neg. pulse. you would have to wire a relay so when it pulses you send power to the switch box. the aux on the compustar is a neg. pulse too.
L T's avatar
L T
You could do it with the arm/lock channel but I like the aux idea better, I think you would too.
gravity5's avatar
gravity5
you would have to use 4 relay though one for each corner....or 1 relay and 4 diodes.
mobileheath's avatar
mobileheath
if you set it up to dump when armed you will also have to diode isolate the arm/lock wire away from the lock/unlock button in your truck....otherwise when you lock your truck from the switch inside your truck will drop
s10
last post by baha +1y
