Lets see some pics of engine bays of bodydropped truck
rainx85@aim.com's avatar
3In2Out's avatar
3In2Out
Also, if you have your motor dropped to clear your hood, what all did you need to do other than dropping the engine mounts?
xmdragonass's avatar
xmdragonass
my 93 bd 4" on 19"S without a z'ed clip, dropped the motor 1" and built a new control arm x-member, did not section the oil pan ,the pan pretty much sits on the ground, still cant fit a stock hood.....
/// xception's avatar
/// xception
check out my profile...not sure how to post pics on here.
3In2Out's avatar
3In2Out
Cool, thanks for the pics. Is it possible to have a stock hood fit without cutting a hole on a body drop to the rockers?
the501clique
whynotfab's avatar
whynotfab
mine's just to the rockers, engine's dropped a little though.. and the cross section support under the hood, is trimmed where the intake tube curves. still gotta Z it though.. then id probably need a cowl or something.
