Audio/Video \  poping sound when i hit buttons
Audio/Video Q & A
views 195
replies 9
following 7
juicedwagon   +1y
hey guys/gals. i'm having a problem with my audio. i have a alpine 9398 head unit running a ppi pc600.2 amp, my problem is whenever my amp turns on and when i hit the track buttons i get a pop sound through my speakers,like it gets a blip of constant power. any ideas of what it could be? thanks for reading
mtm   +1y
bad ground
i_love_primer   +1y
yea bad ground a friend had the same problem except when he turned it on & off
juicedwagon   +1y
thats what i was thinkin so i cleaned them all up and its still there just as bad. i might tear into it and make sure its still soldered good inside
pearldrop   +1y
Bad ground first, bad amp second.
juicedwagon   +1y
i hope i can find it cause the amp sounds good.
bagged300mondubs   +1y
or bad or pinched RCA's
sparkranger   +1y
Mine shuts off it gets too loud.
Example - My moms deck gets up to 20 and its blarring loud. Mine hits 40 and you can barely hear it in the cab.
Low_SST   +1y
its a ground loop caused by a bad ground. there are ground loop eliminators you can buy at audio stores that get wired in line with your rcs'a and they get rid of the feedback. I believe what mostly causes the popping is a bad valve ground.
juicedwagon   +1y
my amp is just fucked, thanks for helpin though
