sanden 708 questions
mazdizzle
I picked up a sanden 708 last weekend to use for an edc and I have a couple questions. It has the oil nut on the top whick would mean it's a dry sump but should I stil use an inline oiler? What size line should I run from the compressor to the tank and what size tank should I use? I have 8 1/2 inch valves and and rear bags are on the way so I'm trying to get everything ready to go. Thanks for the help
gravity5's avatar
gravity5
I have a 507 and do not use an inline oiler....but you will definately need a filter on the outlet.....I have 12 gallons of reserve tanks and it takes like 30 seconds max to refill them from like 90 psi to 155......the 708 should be way faster....and if it has the oiling nut on top it is a wet sump......As for line I tapped mine out and use 3/8 fittings with 1/2 inch line to the filter, then it goes to a check valve, then out to the system thru 2 3/8 inch nylon airbrake lines....but those are gonna get tossed in favour of some hydraulic hose.
