gas tank on 88-98 fullsizes
MrLarryDouglas@hotmail.com's avatar
95FullSiZE's avatar
95FullSiZE
Edited: 12/7/2005 11:38:27 PM by 95FullSiZE
Edited: 12/7/2005 11:36:08 PM by 95FullSiZE
im 4-linking my truck so obviously im gonna drag it, if i relocate the gas tank what all will i need? and i was curious that if when i lay full frame will my gas tank drag cause it looks like it actually sits higher than the frame and is only going to drag cause of the angle my truck sits at and if thats the case would a steel plate under the tank work for now?
95FullSiZE's avatar
95FullSiZE
95FullSiZE's avatar
95FullSiZE
anyone?
Y
yougurt
Since mine is stock floored, I don't know if this will help... But we just sucked mine up. We moved the mounts up about 3/4". It works.
I was thinking about getting a tank from a suburban from a Pick-N-Pull. It's in the back, so you could just get some fuel lines made and be done with it!
Good luck!
Onelofullsize
i used a tank out of a box style blazer...fits perfectly between the frame rails in the rear
bdroppeddak's avatar
bdroppeddak
i notched the rear xmember, and redrilled the holes for the front xmember, and moved it up 3/4". thats on an ext cab.
toreadorxlt
I just did a fuel cell... not that huge of a deal
I
insaneautoconcepts
http://www.finalfab.com they might be able to help
chumpchange's avatar
chumpchange
you can move it up its simple effective and basically free.
