bdroppeddak
well the bags on the axle isnt a big deal, but with the reverse 4 link you lose traction and handling because the bars are attached to the rear of the truck, they dont work like a normal 4 link would, in a normal situation, you push the gas, the rear end torques backwards, using your lower bars to push upwards, actually creating force to hold the rear end to the ground, also creating antidive, where it helps from the vehicle squatting in the rear. because of the same relation with braking, you'll hear alot of people complaining about wheel hop with a reverse 4 link. some of these things may not be noticed as greatly on a slow minitruck, but the signs will still be there.
