Wheel Questions \  Bolt pattern question
Wheel Questions Q & A
views 142
replies 4
unclecorntooth   +1y
Does any one know what vehicles have a 5x4.5 bolt pattern besides tacomas, or where I could find this info.
HotRodDime   +1y
the 89-94 yotas have that pattern, some lexus cars, a lot of vehicles have a 5x4.5
Sigon   +1y
All 6 cyl. Honda Accords
93+ Toy Camry
89+Mistu Eclipse
Mitsu Galants
Ford Mustangs (93+)
89+ Toy Pick Ups including Tacoma
Ford Rangers (All)
Nissan Maximas and 350Z
Infiniti G35 and Lexus IS300
Lexus ES series
the list goes on and on. 5 on 4.5 is probably the most common bolt pattern out there. Most wheels in that size will be a high positive offset and work on your Tacoma (bagged or not). The big difference is the center bore, but if you have aftermarket wheels usually they wheels are bored big enough to fit anything and you might need hub rings.
Sigon   +1y
Another way to look up "5 on 4.5" is to look up 5 on 114.3mm and the list even continues when you look at 5 on 115mm which will also work on your truck.
unclecorntooth   +1y
Thanks for the help!!!
