Daytime running lights
X
xtremeroller
I need to know how to disable the daytime running light feature on my 99 s-10, other than pushing in the parking brake a little. Any help would be great.
W
wheeler
hit the dome interior light button 3-4 times and that does the trick
X
xtremeroller
I tried that but it doesn't work on mine
treylos's avatar
treylos
why cant you just pull the fuse for those day time running lights? or even take the bulb out.
X
xtremeroller
I can't find the fuse and if I take the bulb out I won't have any headlights at all
W
Wakeboard03S10
Edited: 12/11/2005 2:53:58 PM by Wakeboard03S10
Originally posted by treylos
why cant you just pull the fuse for those day time running lights? or even take the bulb out.You can not remove the bulb because its the high beam bulb. Theres the push dome over ride 3times fast untill you turn the truck off... you can either pull the fuse wich always works. The fuse pannle should say wich fuse is for what. If not go to a parts store and look in there hannes manual re quick.
treylos's avatar
treylos
ooo ok i see.
lowchevyon18s's avatar
lowchevyon18s
if u pull the fuse one of your high beam lights will not work
LittleShopLackey's avatar
LittleShopLackey
Push your Emergency Brake down one click, or just push it down slightly until you see the lights go out. My buddy did this on his 99 S10 (5speed) and never had any probs. I know on my 01 Rado I sometime do the Dome Override, but pushing the Ebrake cuts them off as well.
mike
