sonoma front on s10
streetscraper1@yahoo.com's avatar
sonoma front on s10
streetscraper1's avatar
streetscraper1
This is the deal i have a 96 s10 that i want to put a 98 sonoma front on. So can i put the bumper cover over the s10 bumper or will i need to buy a new sonoma steel bumper or a whole new radiator support. any info you can give is good.thnks
HeatWaveDave
i have a 96 also...i put the jimmy frotn end on...didnt need to change radiotor support but i did need to change headli\ght brackets and shit like taht i tyhink it should mostly bolt up tho gl dave
b12yan's avatar
b12yan
you didn't need to change the rad suppport cause ur front is still a pre 98 front end. To update to a 98+ front end you will need a rad support
streetscraper1
so do the 98+ sonomas have a steel bumper under the bumper cover and if it does can i use the s10 steel bumper under it?
9
96ssdownlow
ive got the new 98+ sonoma head lights on my 96 chevy s10 ... how do ya hook the lights up ...like to they sell a conversion harness or wat ?
olskoolpup
youll probably need the noma bumper cuz they have the dip in the middle where the grille goes whereas the s10s dont.
motorheads10's avatar
motorheads10
if you have a 96 you will need a 98-up s10 or sonoma radiator suport. the sonoma grill will fit with the newer s10 bumper the only problem is the gape between the sonoma headlights and s10 bumper look at my profile to see what i meen
