Toyota Trucks \  98 Taco Spindles
98 Taco Spindles
Toyota Trucks Make Specific
views 153
replies 8
following 7
NvrB2Lo   +1y
Ive got a 98 for a daily .. rele want to get rid of it but i need to know y the front wont lay .. spindles ? or control arms ? i have no clue ? help a mini trucker out .. i can tell u n e thing bout s-10 but nothing bout toyota ! Thanx
jetts   +1y
did you flip the upper and lower ball joints?
NvrB2Lo   +1y
i bought the truck bagged and there was alot of shit messd up with the setup .. the upper cups were backwards so i had to fix that but dont know if they been fliped or not
bdroppeddak   +1y
there are no drop spindles for the truck, see if the balljoints are mounted on top of the arms, that would be flipping them. the stock arms will lay on a 215/35/18 after flipping the balljoints, dont think the uppers will lay anything else before binding.
sadisticiron   +1y
20's will lay with flipped balljoints
Scr8pinTaco   +1y
I have a 98 taco that lays all the way around and I have not flipped my ball joints......so I am not to sure what all the hype about flippin them is........and I have yet to be able to find lowered spnidles for it either
sadisticiron   +1y
anything bigger then a 17 or small 18 the upper atleast needs to be flipped to lay out completely full frame
Severed701   +1y
you will also need to z the frame a little bit or drag or cut the shit outta the stock front crossmember...i chose to zmine so i wouldnt be draggin steering rack
bdroppeddak   +1y
thats cuz you're a pussy trevor j/k
