the other day i seen a navigator hitting switches so i went to see if it was bagged or juiced and it ended up being bagged and what tripped me out is that it didnt make any noise when he dumped so i thought he had silencer but he said that the air that releases goes back into the tank, has anyone seen that before and how does it work exactly?
Low_SST
djdaudio designed an air setup like that. it uses the air from your dump valves to fill a tank which was pressure regulated and would flow back through the compressor's head allowing it to pump to a higher PSI faster.
mtm
you need a subject for this thread...nobody can view it
