97 explorer help (Wobbly Steering)
U
9
96explorer
Hey guys and girls, I have a 97 Explorer V8 and my steering wheel just started wobbling when I drive it. I am just curious to see what you guys think it could be. I looked under the truck and nothing. I mean I bet my tires need to be balanced. but I was just getting some extra thoughts. Thanks and have a Merry Christmas to all.
impounded dakota's avatar
impounded dakota
rims could be un-balanced, could have an air bubble in the tire tread, could be mis-aligned, anything's possible, go to a rim shop and have em looked at.
Sigon
He's on the right track, here are a few pointers to check out:
1.)Check that your wheels are all torqued. I have had people get work done at other shops and come in complaining about a shimmy a i walk out there and two of their lugnuts a straight up finger tight.
2.)If the shimmy is at a particular speed then it is usually a balance issue. If it is a shimmy all the time, sometimes it is a bent wheel, movement in a tire, or something else like you threw some weights. See a GOOD (and I can't emphasize enough) tire shop.
3.)Alignments don't cause a shimmy, they cause a pull. But they never hurt to have done when you take the car in anyways.
ontheground
could be the junk rag joints in the steering that ford uses
