maz duh
There is a check plug on the side of the gearbox that you can add oil thru. It's kind of a bitch to fill thru the side without a pump though. You can cure that problem by pulling your shifter and dumping oil in the hole until it comes out the check/fill hole in the side of the trans. When oil comes out the check plug hole you will know that yer full.
