seam sealer
seam sealer
Low_SST avatar
Low_SST
i just was wondering what you guys are using for seam sealer and what would work best under paint and what works best under linex
Idragit avatar
Idragit
I use the fast and firm seam sealer..I think 3m brand...not sure..but heres a good tip..spread the sealer with the gun..then get a cup of thinner and keep your finger wet and run it over the seam to smooth it out...works perfect..and you can never put too much thinner on it..just keep it wet and it will flow perfectly, then it evaporates..just be sure to let it dry for a couple days..its works best under line x ..sometimes it will crack under paint if its a lil thick and you press down on it after the paints on it..cause it will fle more than the paint
Low_SST avatar
Low_SST
any links to get it online?
Low_SST avatar
Low_SST
eastwood has gotta have it right?
redranger92 avatar
redranger92
napa, even napaonline.com RED
bagged&topless avatar
bagged&topless
i didnt c it in my eastwood book
BUILTON24S avatar
BUILTON24S
The brush on stuff that u used works best..the gun stuff can get real messy..i prefer the brush on seam sealer goes on clean looks clean not to thick and hardens very vell
