23s or bags on a c10
RB
Ridin Big Caddy
hey yall i have a 69 chevy longbed n i plan on baggin an bodydroppin it over a set of 23s, Does anyone know whether or not i should bag it first with the 15 inch bobo wheels on there or should i put the rims on first and have my bag setup built around the rims. somebody told me u should put the rims u want to run on first b/c the size of the rims could mess with ur bags r somethin I dont know Yall give me some help here this will be my first bagged ride thanks
KanYon's avatar
KanYon
get the 23's first then bag it. you will need to see how much to cut out of your bed so you can tuck your 23's properly and not rub. you will have to cut the fender wells, and the middle section out of bed over the pumpkin... just on what i know, that would be best
stockflooredsdime
You should definitely bag the truck with the rims you want to run. For example, its really easy to get a truck to lay out on 15" rims, but 23" rims are a different story. If you want the truck to lay out on 23's I would suggest having them around during the bag install or ateast knowing their measurements with the tire you want to run.
david49910
get the 15s with tires similar to the size of the 23s and then bag it. then buy 23s
RB
Ridin Big Caddy
thanks guys i'll go ahead n put the rims on and then bag it thanks yall
