Mazda Trucks \  Whats the difference in the 2.2 head and the 2.0 head?
Mazda Trucks Make Specific
views 206
replies 10
BaggedMazda87   +1y
well?
dssur   +1y
the early 2.0 has manually adjusted valve lash, the 2.2 is hydraulically adjusted. The heads are interchangable.
It was more a year difference than a motor size difference, because the japanese market 2.0 has hydraulics. You can put the manual adjusters on a 2.2 head, in fact you will need to if you run most aftermarket cams.
BaggedMazda87   +1y
Sweet thanks Russ you the man...So the 2.0 head would be better to run if i plan on puttin in a cam anytime soon?
dssur   +1y
either head will work the same, you'll just need the manual adjusters from a 2.0.
I have a whole parts long bed B2000 I need to pick up from where its resting, it had a bad cam (snapped) and has 2.0 adjustable rockers in the front seat next a set of 2.2 replacement rockers.
BaggedMazda87   +1y
Okay so its not like the 2.2 has bigger valves or anything? It won't give me any more compression or anything? I'm jus wondering cuz i gotta rebuild my head(big surprise being a mazda huh?!) and i was jus gonna get one from a yard here, have it rebuilt, and swap it with mine so i was wondering if a 2.2 head would help any but it sounds like their exact except the rockers, correct?
BaggedMazda87   +1y
Oh hey and Russ, would it be dumb to deck the head a lil for more compression without doin anything to the bottom end?
BaggedMazda87   +1y
minitruckpunk   +1y
Your not going to gain all that much with decking the head. Personally I'd say it's a waist of time but whatever floats your boat. If your looking for power out of a Mazda maybe think TURBO.. Lots more fun...Or just throw a bottle on it and see how long it'll last. LOL
BaggedMazda87   +1y
Originally posted by minitruckpunk
"...Or just throw a bottle on it and see how long it'll last. LOL"
hahahahahaDude thats great...yea i figured decking wouldnt do much for mebut i thought i'd ask!...no, def won't float my boat!Thanks for the info tho...So i've heard tons of people say "probe this, probe that; 626 this, 626 that"But has anyone actually done a turbo on a "stock" mazda engine?And had a good turnout??Jus tryin to figure out what to do...Thanks guys
dssur   +1y
shaving the head retards the cam timing. If you want to raise compression buy custom pistons or have some made.
But seriously, modding a Mazda to be fast is kind of self defeating. Get a weber, get rid of the restictive exhaust, and you wont get left behind at stoplights any longer.
The only way I would turbo a mazda is a motor swap. Turboing the higher compression NA motor is asking for detonation, and you'd really want EFI to make it work anyway. A lower compression motor will allow higher boost pressures and less timing retard and therefore make more (and also more reliable) horsepower.
