Axle width questions!!!!!!!!!!!!!
treylos avatar
treylos
I have a '03 gmc and i need to get the rear end narrowed like about 6 inches, is there any other 6 lug rear ends out there that may measure under 66" like off of other cars or trucks. also what company can shorten rear end housings, around louisiana. i dont think the axles can be cut and resplined cause the splined section has a larger diameter than the rest of the shaft.
draggindimes avatar
draggindimes
axles can be cut and shortened but then you would have to send them out to be heat treated and all that good stuff. and dont take the rear to any joe shmoe. narrowing a rear is not just a walk in the park. its very easy to warp the hell out of the tubes and or have a misalignment. in which you would probably have to junk it. so do your homework on the shops.
on20s avatar
on20s
there has to be places in/around houston
bdroppeddak avatar
bdroppeddak
there are like 1000 topics on this, use the search function.
bdroppeddak avatar
bdroppeddak
for example, in the search field enter "narrowing rear" and select "search for all words"
silverchevy avatar
silverchevy
you may want to look into a 4x4 rear end from a 88-98 chevy/gmc truck. same 6 lug pattern and it is narrower than 99-up. the junk yard gave me the wrong rear end and it would fit
silverchevy avatar
silverchevy
currie can do anything for 1g
IMLOWER avatar
IMLOWER
call ekstensive at 281-442-1050
treylos avatar
treylos
there are like 14 topics an none for late model GM trucks! cris (bdroppeddak)
DOWNSUB avatar
DOWNSUB
There is a shop in AUSTIN TX. WWW.AUSTINDRIVETRAIN.COM Give them a call they can help you or point you in the right Direction.
