Toyota Trucks \  Truck wont start
Truck wont start
Toyota Trucks Make Specific
views 281
replies 11
following 8
tuckinlugs06   +1y
Edited: 12/28/2005 2:01:31 PM by TuckingLugs05
well its been going on for a while 1st the starter wouldnt do anything so i hook upa push button to the start worked for about a month now no lights on dash and fuel pump dosnt come on i get nothing when i turn the key but also be4 this happen i drug my wiring harness but fixed it started my truck parked it and now wont start and i here no relays click i checked all fuses what do yall think i know it could be a relay but also could be ign ....but what u think? also is there a kit to swap my efi over to carb or would i need whole new motor
time1   +1y
CHECK THE FUSIBLE LINKS THAT ARE IN THE FUSE BLOCK UNDER THE HOOD.
tuckinlugs06   +1y
i checked all the fuses but im not sure about the relays under the hood
time1   +1y
ITS NOT A RELAY....ITS A FUSIBLE LINK. ITS THE ONES WITH THE CLEAR PLASTIC COVERS OVER THEM SO YOU CAN SEE INSIDE THEM.
SAME THING HAPPENED TO ME ONE TIME AND IT WAS ONE OF THOSE FUSIBLE LINKS UNDER THE HOOD.
tuckinlugs06   +1y
ya i checked thos both thos are fine
tuckinlugs06   +1y
Edited: 12/28/2005 2:25:04 PM by TuckingLugs05
i was thinkin hookin everything up to push start it but then what if that still dosnt fix it...also when i used to start it normally it would make a clicking nose in the cab now nothing
2lowtoy   +1y
kind of sound like the ignition switch the electric parts of it is bad to me
reality05   +1y
the engine harness that runs over the bottom of the intake rubs the intake and breaks the wires , i see it all the time, check that
seansmitty42   +1y
a dead short in the starter will do the same thing
DOWNSUB   +1y
Did you check the hole wiring harness you could have two wires melted? sounds like a short.
