I smell gas
I smell gas
rdcollins
Sometimes I smell gas inside to cab of my mazda. It is bodydropped and the air filter does stick out of the hood. Would this have anything to do with it.
livinlow
no but you can always check you're fuel lines for leaks.That's most likly were the gas is.
tooleyhc's avatar
tooleyhc
Edited: 12/28/2005 3:03:53 PM by tooleyhc
Just light a match, and run it along your fuel line. When it catches fire, VIOLA'! You have found your fuel leak!
DOWNSUB's avatar
DOWNSUB
Where is your gas tank? My sons tank is in the bed and you can smell it some times with the windows down ?
brandon005
I had a leak once it turned out to be the fuel pump it should be attached to the side of the head near the firewall on the pass. side
dssur's avatar
dssur
If you ditched the charcoal canister and plugged the line, you are forcing gas fumes out the vented cap.
Make sure you didnt cut a line doing the bd.
Mazda gas tanks rust along the seam in the center, giving you a gas smell. It gets bad enough that you wont be able to run over half tank or all the gas will just weep out through the rust.
