easy way to narrow a rear end on a ranger
bodydropped85@yahoo.com's avatar
bodydropped85's avatar
bodydropped85
ok i figured out the easiest way to narrow a ranger rear end a couple inches. since one side is longer than the other, get another short axle and narrow one side to match that axle. then the rear end would be centered in the truck instead of offset.anyone see any problem in this? im gona try to have my rear end narrowed by blooddrag....
dwnlowx
every car rear end is usually not centered
cookiemonster13's avatar
cookiemonster13
YEHA I HAVE DONE THIS BEFORE. NOT FOR A RANGER BUT ME AND A BUDDY OF MINE HAVE DONE IT BEFORE.
MM
mr mufakka
Wouldn't that put an angle in the driveshaft (side to side) since the tranny output won't be inline with the pumpkin u-joint?
Also, which I'm sure you've though about, you'd have to redo all of your link brackets.
periportfd
Sounds good. Only problem I see is if you have anything real close to the driveshaft right now. Usually the center section is offset to make the pinion centered so by centering the rearend the driveshaft will probably run at a slight angle, possibly causing interference with a gas tank or bracket.
cookiemonster13
this is all very true and when i did this it was a scratch built hot rod so the tunnel was built... so on and so forth
bodydropped85
Edited: 12/30/2005 3:40:53 PM by bagged85
yea igota fuel cell there is nuthin in the way. i see what mr muffaka is talkin about tho but i dont see y it couldnt be adjusted out....yeai plan on 4 linkin it at the same time no biggie.
Dejavu's avatar
Dejavu
my buddy did this on his ranger... works great... good luck
Low_SST's avatar
Low_SST
they do it on dakotas too... flip the axle from the small side to the long side and shorten the tube.. and then get the long axle shortened and reslined and shorten the short side the same length. So basically you still shorten the axle tubes the length of the shorter axle and you only have to shorten one axle so it fits in the shorter side.
this description is fucked up if you want a pic i can supply one
