Body work and Paint \  My compressor went Bust!!!! Ugh...
Body work and Paint Q & A
views 128
replies 0
following 1
Only1Platinum   +1y
Okay guys, I have a coleman 27gal 5hp 90-125psi air compressor. however coleman doesn't make parts for it any more. Its got one of these nasty manifold things setup on it and the valve has gone bad. only way I can think to fix it is to re-plumb everything. This is my first time attemting something quite like this. and I wanted to get some input from you guy how to best go about it before I go buying all new parts.
The pressure switch off of it should be able to be re-used along witht he guages. all I think I will need to buy is a regulator to send air out to the hose.
There is only one main outlet on the top of the tank for me to work from aside from a few smaller ones on the side air plugs in them to realease built up air pressur when I pull on them.
Does anyone have any links or instructions how I should pipe this thing off to make it work again. This is really pissing me off not having the thing working or anything. Here is thre break down I think I have so far and I think it will work.
I need to split my one opening on the tank in to three openings I believe.
in one one of those openings I plug the output form the motor to. the other I put my pressure switch and the other have the regulator plugged up with the passthru going to my hose quick connect. I would emagine I would also want to put a check valve down close to the tanke on the first opening and feed that back to the pressure switch right? I hope this makes since. if someone more knoledgeable could help me out it would be great. I will see what kind of responce I start getting now from this. thanks in advance guys.
