Offset problems
dooredford@gmail.com's avatar
Offset problems
DooredFord's avatar
DooredFord
OK so I just recently bagged my truck using the KP Components 6-link w/ cantilever. The problem is my wheels I'm using DUB Shoreline's they only offer them in a 10mm offset. They tuck up front, but since the panhard shifts the axle to one side when its laid out, the rear wont tuck. What offset wheels do I need in order to tuck the rear? It's a 2000 F150 by the way.
DooredFord's avatar
DooredFord
anyone?
Sigon
Are you sure your rear end is centered right? Just asking because it may be an easy fix, plus your +10mm offset is only important if we know the wheel width that goes along with that. Let us know and maybe we can help you out.
E
exploitedcustoms.com
I would check the measurement from wheel to bed lip on both sides make sure that everything is centered when it's aired up. The axle shouldn't be shifting that much that it's not allowing you to air out.
1fastlx
sounds like you have too much angle in your panhard bar, the closer you can get it to being level, the less it will shift the rear from side to side. I am not saying you can keep it level, just that the less angle you have, the less it will move laterally
