bagging 01 f150 supercrew
Lo Range avatar
Lo Range
ok guy's i just got my supercrew i want to bagit i have the rear all planned out but im getting nowhere when i ask about baggin the front how do i get it to lay out in the front and can i use a set of cups for brackets? what's this i hear about flipping the spindles? or was it ball joints? well input is welcome and pics if you got them TANX L8r.
DooredFord avatar
DooredFord
DJM control arms, slam specialties RE6 bags, KP components bag cups (not listed online had to call for them), notch the frame for the tie rod ends, cut out the fender wells, relocate battery, fuse box, push computer plugs through the firewall, thats what i had to do to lay it out up front.
jmn444 avatar
jmn444
i'm 2" or so from the ground... next step is the computer plug shit for me, what do you mean by pushing them thru the firewall? i thought i was going to need to cut a section of firewall out and move it up to make it right...
also, i used bell tech spindles instead of the lca's and since i had to flip the tierod when i installed them it looks like i might not need to notch the frame for tierod clearance... not sure yet, but might be something to consider if you haven't bought any front end parts yet! can't run smaller than a 18" rim w/ the spindles though... not that you'd want to on a F150!
gonz avatar
gonz
a stock f150 will lay frame on 20s with stock control arms notched for the frame to lay through. thats how mine was for several years.
Grounded 4 LifeGonz
