where can find a list that shows all blot patterns
OGDOUGHBOY
if you know the year make and model your looking for try searching for wheels for it on tires.com and it should give you the bolt pattern for that vehicle
bagged&topless
i just want to know what cars trucks have the same bolt pattern as my truck
rwloper
If it is the s10 then I know camaros, trans ams and vettes for sure
Balzout Sparkin
S10 is 5x4.75 or 5x120.6(I believe, not sure on the .6) Anyway, That is the same as all Camaros and Trans Am's but the backspacing changed in '93. All Corvette's but again backspacing changed in late 80's/early 90's??It is also the same as all Rear wheel drive Monte Carlos, Cutlass', Buick Regals, Pontiac Grand Am and Grand prix (rear wheel drive only). BMW uses 5x120 on some models not sure which but they will still slide right on an S10 backspacing is still an issue and I think some Jeeps even use that bolt pattern, maybe not sure. There's probably others out there. HTH Later
Wel if you use a BMW wheel make sure it is out a 5 series and not a 3.
FYI if you take 4.75 and X by 25.4mm(number of mm in an inch) it comes out to 120.65mm.
But you can also go to Discount tire direct.com for a list of bolt pattern's
