still Bodydroppin
11 following
Y
still Bodydroppin
rollinjunk
Can somebody please give me some help on what to do with master cylinder and brake booster? Its an 87 pickup on 17s looks like the booster could work if the camber was aligned strait but dso you raise or recess the resevoir? and how do we do the any pics would be great, and what about a smaller booster?
time1's avatar
time1
I have a 91 yota and its BD 3 inches and my 18's just BARELY come in contact with the booster when layed out. I do have drop spindles tho and that helps a little bit with the negative camber. you can get a smaller booster from another truck...i think the automatic trucks have a smaller booster. You could do the geo metro booster, but i have heard the brakeing isnt all that great.
cnudrln
i used one from an earlier 4x4 yota. mine worked great before i redone my firewall. now i completly shaved everything.
whynotfab's avatar
whynotfab
I think Im gonna see if mine barely touch once I get spindles, but the clutch cylinder will definitely have to be moved up a little and recessed in or something.. check through threads on here, I know other and I have asked before and got good tips/pics. good luck man
REDOVAL
I put my clutch master sylinder under the dash using a swing linkage design. Leaves the engine side of the firewall completely smooth with plenty of clearance for a big wheel/tire combo. I will try to get pics up ASAP so you will have an idea...it was not that hard to do and works great. Check back in a day or two on my profile and I will post them.
REDOVAL
I forgot, also check out Sadisticiron's Toy, his is under the dash and looks like a great alternative as well.
twisted976
hey can i use a geo metro booster on my 94 s10 bodydropped on 19s
twisted976
hey can i use a brake booster on my 94 s10 bd on 19s
bdroppeddak's avatar
bdroppeddak
if anyone wants the booster, i have an 89 toyota that was an automatic, guess it has the smaller booster?
kindalow
i used the stock units and just moved them both up and over, no problems really.
