blinker problem?????
13 following
N
blackrado
i got a 97 s10 with supra lights. the problem im having is when i go to turn right both my blinkers on the supras blink, but when i turn left it works normal. what could this be it just now started and i have no clue.... thanks
blackrado
neone?????
unluckys10's avatar
unluckys10
low on blinker fluid?? just messin...it was workin fine then all of a sudden started doin this??
blackrado
yeah
PleasuresBurban's avatar
PleasuresBurban
Change the bulbs out first..May seem gay..But the bulb could be shorthing out. I would almost bet thats your problem.
N
nrre
the first problem is the supra tail lights...and now u have a problem with the blinker, ouch.
lol i keed i keed.
check the blinker relays/switches make sure nothing is crossed. check the wiring. the usual stuff.
cookiemonster13's avatar
cookiemonster13
i dealt with this type problem before. make sure there is not tons of diaelectric (sp) grease in the socket. it can sometimes confuse stuff. i had this safe problem same lights on a dually.
eyekandydesigns's avatar
eyekandydesigns
If the installer used any diodes (I used them in mine - they restrict the flow of electricity to one way so it can't come back through the wire) that sounds like what is happening. Fill free to email me if you think this might be the problem and I will be glad to explain it more fore you.
-rj
cantlooswit22s's avatar
cantlooswit22s
i was goin to say the same thing
PleasuresBurban
So what was it
