Blinker FLasher?
mavverik@sbcglobal.net's avatar
Blinker FLasher?
TwistedMinis's avatar
TwistedMinis
Where is the flasher, or circuit breaker that controls the blinkers located? I can't find thi stupid thing. My blinkers don't flash, they just turn on. Same with the hazards.
taco2nv's avatar
taco2nv
what year, on my tacoma i thin it was behind the lil fude box under the dash. if not its in the second fuse box under the hood.
TwistedMinis
In an '80 Yota. There are no fuses under the hood. And it's not by the fuse box under the dash. I found the buzzer box, and the headlight relays, but I can't find this one...
I know they're normally by the fuse box under the dash.
corey0814's avatar
corey0814
i don't know about an '80 but typically if the blinkers stay solid it means that one of the bulbs (front or back) is burned out. on an '88 it's under the drivers kick panel.
simple-pleasurez's avatar
simple-pleasurez
it could be your blinker fluid is low. i would check that first
sadisticiron's avatar
sadisticiron
what year seth? so i can find it in our computer at work
TwistedMinis
1980. Thanks Bobby.
tenagator's avatar
tenagator
seth maybe the blinker bearings are shot?? haha
