using a stock headunit
framescr8pintoy@gmail.com's avatar
framescr8pintoy's avatar
framescr8pintoy
my wife has an 05 corolla S and i was ponderin the idea of throwin my subs and amps in the trunk since i hardly drive my daily driver anymore. i dont really want to replace her cd headunit just cause of the way the dash is shaped where an aftermarket headunit would i think look funny.and to just basically keep it stock looking. isnt there some kind of harness that can be wired in to hook up my amps etc. like on an aftermarket headunit?
lkrayzie's avatar
lkrayzie
i know radio shack sells an adapter that you hook up to your stock wires on the rear speakers, then it turns them into RCA jacks
framescr8pintoy
so i would end up losing my rear speakers?
fatheadjames's avatar
fatheadjames
Get a lineout converter. It installs on your speaker wires and turns that into rca out. No you don't lose your speakers.
sccustoms
yep, use a lineout converter. and no you don't lose your rear speakers, you just tap the rear speakers into it. it just sends the signal to the amp. it's no "as good" but i've installed one in a customers car for the exact same reason, and it didn't sound bad at all.
framescr8pintoy
what would somone suggest as a good brand for one? i would be wiring up two audiobahn amps with 2 15's if that helps.
Twisted Galant's avatar
Twisted Galant
I would use PAC"S interface, Hi/lo level converter. Has adjustments on the side, reliable and small.
