CADDY WHEELS and Z WHEELS
Fazethree6661@hotmail.com's avatar
Fazethree6661's avatar
Fazethree6661
Hey I know Z wheels and CAddy wheels and all that fit on the DAWGS but what all is involved in putting them on?? does the center bore just need to be done or what???? somebody help me out the is for a 89 B2200 thanks guys....
impulse's avatar
impulse
you can bore them out, or you can grind off the tabs on the hubs (i did that and havn't had problems)
dragginmazda86's avatar
dragginmazda86
you just need the centers bored out or do what i did grind down the tabs.
Fazethree6661
cool how hard is it to do that?? the grinding that is... thanks for the info
dragginmazda86
on the front i took the hubs from the rotors, pounded out the lug studs and ground the tabs smooth, then pounded the studs back in and put it back together the back i put some old lug nuts on the studs and ground them with a die grinder.
nascarguy3's avatar
nascarguy3
GRIND THE TABS DOWN AND INSTALL WHEELS, I HAVE NO PROBLEM WITH MINE.
kaoss's avatar
kaoss
i only had to grind the back hubs with my z71's.
And grinding is grinding, does it get easier?
im2lo4ya's avatar
im2lo4ya
does gringing off the tabs do anything for the balance on the axle
kaoss's avatar
kaoss
^^^^it could...you'll also need new lug nuts. I got mine from discount tire
