Body work and Paint \  removing powdercoating from aluminum
Body work and Paint Q & A
views 159
replies 7
following 6
luv2sprk   +1y
does anybody know the easiest way to remove powdercoating from aluminum without messing up the aluminum. i need to remove the powdercoating from a motorcycle swingarm. thanks.
luv2sprk   +1y
bump
brandon005   +1y
buy a new swing arm powdercoating is a bitch to get off and you will mess up the swing arm in the process
Bdierks   +1y
Its called aircraft stripper or aircraft remover. it will take it off. i think i got it at the auto paint supply store. Comes in a spray can. i have used it to strip powder coat and it does work.
hope this helps.
JFcustoms   +1y
haha i bought a cr 125 and the guy had powdecoated the swing arm black, i took it off and put some jasco stripper on it and it flaked off in big chunks, then i just wire weheeled all the spots it didnt get and polished it up
ndaweeds   +1y
yup i do powder coating and all i use is an aircraft paint stripper. BUT if its a 2 step color ive found out its a bitch to remove. the powder coat doesnt let the stripper get under both coats to lift it.
Low_SST   +1y
soda blast it.
luv2sprk   +1y
thanks alot for the info, i'll try the aircraft remover. and its orange, if that makes any difference, i don't know what a 2 step color is
