SFBD 1stgen blazer?
SFBD 1stgen blazer?
Lowrddreams
I was wondering if anyone has any pictures of peoples frames and finished projects on the blazers? I'm wanting to buy another frame to build so I can keep driving my truck while im making the new frame. thanks yall
mindlissmetalfab's avatar
mindlissmetalfab
damn, you again? haha.
If you want to build the frame while still driving yuor truck, buy a complete blazer chassis and start with that. Build your new frame inside the old frame and lower your bodymounts. When the frames all done, take apart your other truck, section the cab mounts for whatever extra drop you need, then put it all together on the new chassis.
mindlissmetalfab
4UH8RS did his BD that way. It eliminates trying to figure out where to put bodymounts which you would need to do if you were building from scratch.
http://www.streetsourcemag.com/ViewOwnerProfile.aspx?Home=true&ProfileID=34307
theres a couple pics of his there. He can probably get you some more if you email him
blazedout84's avatar
blazedout84
i did mine a completly different way but i wasnt needing to drive it at the same time so mine was different. took measurements and squared things up. check out my profile it might help
