converting mm into inches
2manytoyz
+35 into inches
91 drggn dime's avatar
91 drggn dime
there are 25.4mm to 1 inch.
cruisinlowS10
35mm is 1.377949 inches.
Low_SST's avatar
Low_SST
hey you guys can go to google and type in
35mm to in
as a search and it will do the conversion for you
in fact you can do it for most units of measure and it will convert for you.
2manytoyz
so that means 1.3 inches of wheel lip or the dish
lyinlow's avatar
lyinlow
just multiply your mm by .03937 to get inches
dssur's avatar
dssur
no. that means that the wheel mounting surface (the flat part that sits on your hub) is offset 35mm from the centerline of the wheel. The "=" means it is offset to the front side of the wheel, if it was -35 it would be offset to the rear side if the wheel.
Offset if dependent of the width of the wheel, so BE SURE you know the width when you ask offset questions.
2manytoyz
thanks russ-d youve been a big help
Low_SST's avatar
Low_SST
offset is esay to calculate...
fisrt take the width of the rim and add an inch.
then take the offset (+20 for example) and convert it to inches. 20mm=0.787"
then you add that to the first value you calculated( if its a 9" rim you would add an inch to make it 10" and when divided by 2 you would end up with 5) if your half rim value was 5 then your back spacing would be 5.787"
if you have yout back spacing and you want to calculate your offset you can work backwards
and find the difference between your back sapcing and the half rim value ( ex. if you had 6" BS and half of the rims was 5" your offset would be 1" )
you can then take the inch value and go to google and type this as a search
1 in to mm
and it will convert it
you can also type 20 mm to in and it will do that as well.
this is a post i made for someone else on how to calculate offset from backspacing and backspacing from offset.
