Isuzu \  drop spindles for a 1984 pup
Isuzu Make Specific
views 484
replies 7
following 6
blu ballz   +1y
will 2" drop spindle for a 88-93 work on an old pup
dragalac   +1y
You can get drop arms from BYC if you can get him to make them and it works just as good as drop spindles
bdydrppup   +1y
no they will not fit been there tried that ball joints are different ,control arms will bolt up from that body style but they wont work either because they are 2" longer than yours. you either have to step your control arms or make some
FreakwitaFro   +1y
im not sure if there are any diffences in the 84 and 86 isuzu suspension but i know my buddy has 2in drop spendles on his 86. i know he changed the ball joints out and changed out some other stuff too. his profile is http://www.streetsourcemag.com/IM/ViewUser.aspx?IMStyle=&ID=NVRDUNIZU
blu ballz   +1y
thanks for all the ifno. guys
blu ballz   +1y
trevor how could I get a hold of your friend with the 86 pup(email addy)
olskoolpup   +1y
yea man, no go on 81-87 drop spindles. im having arms made by BYC so i can lay. the other way to lay out fully is to cut out the section of frame above the lower control arm and rebox it in. you will have to re angle the upper balljoints as well. its quite a bit of work.
my truck is about 2-3 inches from laying cuz i didnt want to hack all sorts of shit up like that on my only ride. not saying that it cant be done right, i just dont have the time to do it that way. id rather wait for arms so it can be done in a weekend.
nvrdunizu   +1y
I HAVE 2 INCH DROP SPINDLES ON 86 THAT CAME OFF OF A 88-93 ISUZU. I HAD TO SWAP OVER RADIUS RODS UPPER AND LOWER BALL JOINTS AND TIE ROD ENDS ALL OFF A NEWER ISUZU. THE ONLY PART THAT SUCKS IS YOU HAVE DITCH THE SWAY BAR
