need info on under hood compressor
8
86mazyota
what does it take to run an underhood compressor on an 86 b2000. Parts and know how will be helpful.
Thanks in advance
balcar's avatar
balcar
I can't remember if its like a b2200 under the hood, the one I did, we had everything stripped from the motor exept alternator. (had weber conversion and header), located it just under the distributer.
24HourRoadDotRemoval
we did on on my buddies truck you can mount it where the ac goes but you will have to mount it at an angle and it doesnt look that clean or you can do what we did and move your alternator to where the ac pump goes and make brackets to mount a york where the alternator goes if you want some picks let me know ill take some and post them for ya good luck later P
no regrets . wa's avatar
no regrets . wa
Edited: 1/22/2006 11:44:34 PM by farside customz
why doint you finish your shit and quit messing with other peps stuff. come on get with the program fucker . ha ha ha jk
prorida's avatar
prorida
IF your gonna run a bdc i don't think they make braket kits for yours so you'll probally have to fab, you gotta run a york not an ac pump i went through about three sanden's before i went to york. it's like haveing a rotery engine and piston engine. with the rotery (sanden) non stop maitnence and oiling, with a york check your oil once a week and your good to go. fab a bracket to line up the pully from the comp to the rest of the acc's you might have to move an idler pully or mount one off the mounting bracket for the comp, then take a string run it around all your acc's and your new comp pully then take the string measure the inches, call up NAPA and get a belt with the size inches. hope this helps
lukeinva
I would like to see some pics of that!
bagman
what sanden did you use...i never have to do anything to mine...a little squirt in the intake once a week,been goin for 3 months or longer
mazberrydelight's avatar
mazberrydelight
on my profile the xtra cab mazda has pics of the EDC in it . with power steering.
bagman
mine is edc and power steering as well
