yota front stabilizers?
17 following
royaltz2001@aol.com's avatar
tenagator's avatar
tenagator
will i have to get rid of thses stabiliziers that come off the lower control arms and mount up to the front under the radiator? there for sway i imagine?? i will be body droppin and z'ing. do these stay or go??
bdroppeddak's avatar
bdroppeddak
those bars are what triangulate the lower arm, without them it would move back and forth, which is not good.
crux131's avatar
crux131
They stay.
You might be able to take them out and run them towards the back of the truck, and make new mounts under the cab. Or maybe move them up front, but you need the strut rods unless you swap to something like the kustom werks control arms. Then you can ditch them.
whynotfab's avatar
whynotfab
Pasting this from a reply I posted a while back, hope it helps!
Of course tubular lowers would work, but cost alot more. What was done on my brothers truck, and I will probably do on mine unless I get me a set of KustomWerks.. is reverse the rod off the back of the LCA to the framerail.
Pick up some of these, (right hand/left hand threaded), some Jam nuts, dust caps..
All can be found at SpeedwayMotors.com - LINK oror
and
Then you'll need to measure to see what length bar you'd need, and SpeedWay also sells bars that'd work (just be sure to get the right size according to your rod ends):
They have those: Swedged 6061 aluminum radius rods. 1" O.D., 5/8" NF threads. LH threads on one end. RH threads on the other end. - at different lengths.
LINK
Then you'd just need some tabs, fab some up.. or buy some, A&A Manufacturing has a variety of tabs also.. LINK
Edit - at one time, a while back I had it all priced out and was I think $80 but don't think that included tabs/hardware. Hope that helps.
tenagator's avatar
tenagator
thanks alot!!!
btu do i really really have to move them to the rear? instead of facing th fron of the truck? whats the advantage or disadvantage. i know they must stay sinc e im not changing the control arms.
whynotfab's avatar
whynotfab
Nah man, if you see a way ( i havent really worried about it yet on my truck ) you can just move them a little to where everything works. johnny (hopntoy) I'm pretty sure built new brackets off the frame and reinforced it all, cleaned it up to look pretty much better/and be stronger than stock, check his profile out, maybe get in touch with him. Reversing is just one option.. good luck bro!
Severed701's avatar
Severed701
you can leave them right where they are at..just cut off the part of the bracket that bolts to the front frame..and brace them up..then you will have to have your lower radiator port moved over to clear the end of the rod..but its alot easier than building new ones i would say
whynotfab's avatar
whynotfab
Are some of our radiators plastic at the bottom? I thought i remembered someone mentioning that before.. I honestly can't remember if mine is lol.
Severed701's avatar
Severed701
yeah i forgot to say that..u need a metal radiator
sadisticiron's avatar
sadisticiron
Edited: 1/23/2006 6:42:00 PM by sadisticiron
its right here take a look simple. the radiator fits in the drop down
