Isuzu \  isuzu pup's
isuzu pup's
Isuzu Make Specific
views 315
replies 9
following 7
mightymini   +1y
I'd like to see some pictures under the hood
mightymini   +1y
when i lay out my front my tires tuck under and hit some kind of support and wasnt sure if that had to be cut out or maybe i had the wrong offset on my wheels. Kinda hard to explain without a picture. But it runs from the firewall to front rad support i think and when i let air out this pretty much lays on my tire
dragalac   +1y
part of being a minitrucker time to cut
bobby7m   +1y
could this be the steering linkage hitting the frame or even the front stabilizer bars that keep the caster correct for the alignment. At first I had mine flipped to the opposite side, cut and re-welded. That worked for awhile then I just had custom upper and lower control arms made to eliminate the strut rod altogether, Sort of like S-10's with A-arm style uppers and lowers. I might have a pic in my profile but probably not one with a tight close-up of what you're talking about.
mightymini   +1y
its more like support that goes from firewall to rad support. It just seems in the way but dont wanna cut it if its that important.
dragn168   +1y
the only thing i ever saw in my truck that ran from the fire wall to the radiator support was the wheel well and those gotta go to lay out on stack wheels and tires if you got 16's and low pros you probly wouldnt have to ditch it but i know they gotta go for 18's
Dupa102933   +1y
just take a look at my profile and you can get a good look at nothing being in the engine compartment except da engine.........its all ya need
mightymini   +1y
it was the piece that the fender attached to across the top.....looks like i dont need the damn thing..lol...thanks for the help
FrameLayN88   +1y
My 88 Isuzu Pup Layed out on 20x8.5 with 35 S. Tires!! The only thing I did was Notch the rear, cut off the front brake line bracket and bough 2" drop spendles.
FrameLayN88Isuzu
FrameLayN88   +1y
I also cut out inner finders and part of what brace that the inner finders are part of!
For anything else message me or look at my profile!
FrameLayN88
Iuzu
