Dodge Trucks \  94-02 ram suspension
Dodge Trucks Make Specific
views 157
replies 4
low95xlt   +1y
i need suspension pics of bagged rams for the front can't find anything in the profiles,
dodgemanwith20s   +1y
check out my profile i got some pics of mine in there
low95xlt   +1y
can i still use my djm with a afetmarket bag bracket and be done?
Low_SST   +1y
yes and no
i have djm control and you will need to cut the tops off your inner fenders, trim the shit out of your spring pocket, remove your shocks, and sway bar. you will also have to trim off some material behind the spring pocket because it will hit the tube onthe back of the control arm.
I plan on removing mine and putting a 1/4" plate on the lower instead of the pocket, and then pie cutting my upper arm and changing the angle a little to help with balljoint angle.
Low_SST   +1y
btw the cups for the dodge are 5.5" od and you can make your own very easy, just get the kit from suicidedoors, or call larry at innovative and get some tubing and plates.
